Basics: Binary Output
A project log for Experiences with ESPhome
Setting up some ESPhome-devices
mabe42MaBe42 a day ago0 Comments
This can be something like a LED or a relay that can be switched by switching a digital output.
There are several possibilities to do this which end up in slightly different appearances in HA:
Output - GPIO
output:
  - platform: gpio
    pin: GPIO13
 But this does not show up in HA.
If you want it to be shown in HA, you can for example use
Light - Binary Light
You need to add a few lines to the above. The result is:
output:
  - platform: gpio
    pin: GPIO13
light:
  - platform: binary
    output: gpio_d7
 As you see, in the light you refer to the output's id.
The result looks like this in HA:
You could also define a
Switch - GPIO Switch
The code is:
switch:
  - platform: gpio
    pin: GPIO12
 Result:
or you can use
Switch - Generic Output Switch
Replace the above code with:
output:
  - platform: gpio
    pin: GPIO12
switch:
  - platform: output
    name: "Generic yellow switch"
    output: gpio_d6
 Beware, you can have only a single output section. So together with the red LED it looks like:
output:
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO13
light:
  - platform: binary
    output: gpio_d7
switch:
  - platform: output
    output: gpio_d6
 And the result in HA:
And there are other components which in the end only toggle a GPIO between 0 and 1.
