The more I used ESPhome, the more confused I got. So I decided to start over again and provide some examples for things I had understood or which at least I thought I had understood.
I took a Wemos D1 mini board and generated a new yaml to which I just added a wifi sensor, as it's always good to know the wifi strength when testing.
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
password: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Eh-Test Fallback Hotspot"
password: "password"
captive_portal:
sensor:
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 10s
As for the wifi credentials, it's necessary to create a secrets.yaml in the same directory as the above yaml file and provide the credentials there:
wifi_ssid: "your_ssid"
wifi_password: "your_secret_password"
In home assistant (HA) this can then be seen as
![](https://cdn.hackaday.io/images/125911739043336543.png)
(Settings -> Devices & Services -> ESPHome -> Devices)
