28/11: I modeled new bearing supports with the correct dimensions (because I modeled a first version based on other bearings) and printed them. I had trouble to fit the ball bearings inside so I filed the edges of the holes and with the vice I finally made them fit. Unfortunately, the dimension were not so good for the screw holes and they were too breakable so I'll need to make modification.
Sylvain
