Whitelisting Is Now Optional
01/03/2025 at 21:27 • 0 commentsTo keep spam from showing up on your display, FriendlyStack Reminder filters your messages and will only show messages sent from specific email addresses. As this functionality was enabled by default, no task would show up, if you did not specify any whitelisted addresses. As some users were confused by this behavior, filtering is now off by default and will only be enabled if whitelisted addresses are specified (see picture below). The firmware and the instruction manual have been updated accordingly.
To update your FriendlyStack Reminder just reinstall the firmware (all settings will be retained).Keep the feedback coming, I'm listening to you...
One More Case Option
12/13/2024 at 13:48 • 0 commentsFor those of you who like to push things a bit harder, I've created a variant of the case, featuring a larger base so it will not tip over. Additionally I added a reset button for convenience. Yo will find the new model on printables.com
