Software setup
A project log for Italian Word Clock
It tells you the time with RGB leds, already working on a talking version that also moves the hands
esenesesenes 10/13/2024 at 20:200 Comments
Start with a fresh installation of raspbian OS, with internet access (either via ethernet or setup the wifi connection when you flash the SD card).
During the installation, create a sudo user called clockPi'.
Make sure that you run
sudo raspi-config
and select the appropriate time zone !
Keep the time synchronised:
Install the NTP service to keep the time synchronized via web. In this implementation there is no NTC module, so we will have to rely on the web for that.
Run in a terminal
sudo apt-get install ntp
 then configure it (for servers in Italy)
sudo nano /etc/ntp.conf
and write inside
server ntp1.inrim.it iburst
server ntp2.inrim.it iburst
server time.inrim.it iburst
then save and exit. Restart the service with
sudo service ntp restart
and you should be good. Check the status with
sudo service ntp status
Dowload the scripts from github:
Create a folder to host the scripts called "wordClock"
cd
mkdir wordClock
download the scripts in the Scripts folder at https://github.com/esenes/Word-clock, and copy them inside the wordClock folder in the raspberry pi.
Install the Adafruit-Blinka library:
First of all you need to get the Adafruit-Blinka library
sudo apt-get update
sudo apt-get -y upgrade
sudo apt-get install python3-pip
sudo apt install --upgrade python3-setuptools
sudo apt-get install python3-full
then reboot the raspberry pi.
Create a virtual environment for the python script to run:
Move inside the script folder
cd
cd ./wordClock
and create a virtual environment called "env"
python3 -m venv env --system-site-packages
 once it's done, activate the environment and install the neopixel libraries
source ./env/bin/activate
Install the libraries for the neopixel LED strips:
pip install rpi_ws281x
pip install adafruit-circuitpython-neopixel
And as last touch go to disable the audio on pin 18 if that's what you will be using. Go to /boot/firmware/config.txt and set dtparam=audio=off
Test that everything runs:
/bin/bash /home/clockPi/wordClock/run_clock.sh
 The clock should light up and visualize the time
Enable the script to run at startup:
Go edit the rc.local file
sudo nano /etc/rc.local
and add this line before the exit 0
/bin/bash /home/clockPi/wordClock/run_clock.sh &
 It's all set
You can reboot the pi and see what happens
sudo reboot
Rich text editor
