QT - SAO
SAO 1.69bis to QT Stemma architecture adapter
Public Chat
I noticed that most of the Adafruit QT Stemma i2c devices have a common pinout and a common wire harness. Just a quick little adapter enables tapping into a who architecture of toys off of a badge.
Some easy wins here, but the pinouts are not as similar as one might hope.
Still, poc on a perf going well. Just might need a lil more assistance from hand soldering or jumpers for the variances
  • Riffing on davedarko's Schedule SAO
    JonKangas • 10/17/2024 at 19:45 • 1 comment
    Davedarko was way ahead of me. He has a perfect little board that breaks out the pins for an add-on module.
    The modules I have been eyeballing have the pins swapped, so I stole his work and modified it including removing the nice calendar silkscreen and adding a header for swapping data and clock. I also move vcc to the end because more of those are available on the adafruit modules I have coming. I sent off an urgent order to OSHpark since I am in PDX and I think they can pull this off in time.
    I have no idea if there will be room for the headers on front or on back. May need to solder blob it.
    beats deadbug by a smidge I think...
  • Sorta better
    JonKangas • 10/15/2024 at 19:40 • 0 comments
    Enamel wire helps, though half perf half bug is not a great look.
  • Woah, this is uglier than the postit
    JonKangas • 10/14/2024 at 20:08 • 0 comments
    Amazon brings me things to test soon
  • Adafruit order
    JonKangas • 10/14/2024 at 17:24 • 0 comments
    ordered an assortment of adafruit i2c devices to play with.
    Dangling headers off a badge and connecting wires all over seems like a horrible idea. Proceeded anyway.
  • Inspiration struck
    JonKangas • 10/14/2024 at 17:23 • 0 comments
    ordered headers, wire and some perfboard
    Drew a terrible schematic
    I sort of expect this to be either a duplicate of someone else’s work and I’m just making notes for myself, or I’m just lazier about this hack than anyone would have ever imagined.
View all 5 project logs
