Riffing on davedarko's Schedule SAO
10/17/2024 at 19:45 • 1 commentDavedarko was way ahead of me. He has a perfect little board that breaks out the pins for an add-on module.
The modules I have been eyeballing have the pins swapped, so I stole his work and modified it including removing the nice calendar silkscreen and adding a header for swapping data and clock. I also move vcc to the end because more of those are available on the adafruit modules I have coming. I sent off an urgent order to OSHpark since I am in PDX and I think they can pull this off in time.
I have no idea if there will be room for the headers on front or on back. May need to solder blob it.
beats deadbug by a smidge I think...
Sorta better
10/15/2024 at 19:40 • 0 comments![]()
Enamel wire helps, though half perf half bug is not a great look.
Woah, this is uglier than the postit
10/14/2024 at 20:08 • 0 comments![]()
Amazon brings me things to test soon
Adafruit order
10/14/2024 at 17:24 • 0 commentsordered an assortment of adafruit i2c devices to play with.
Dangling headers off a badge and connecting wires all over seems like a horrible idea. Proceeded anyway.
Inspiration struck
10/14/2024 at 17:23 • 0 commentsordered headers, wire and some perfboard
Drew a terrible schematic
I sort of expect this to be either a duplicate of someone else’s work and I’m just making notes for myself, or I’m just lazier about this hack than anyone would have ever imagined.
