I think frame-mounted sconces work better.
The first attempt (uploaded as "blink1SconceFrameArch1.stl") is much more stable than the PCB-based mounts.
Problems with this first attempt though:
* mounting arms block some of the side-emitting light
* mounting grippers are 2mm too wide on each side
Thus fixes to try:
* move mounting arms forward towards USB jack: gives more space for light
* eliminate 2mm space on grippers
