I enhanced the prototype code to implement animations for PLAY, PAUSE, REWIND, and FASTFORWARD -- video of latest functionality is at the bottom of this project log.
I included an indexing offset to imitate the asymmetric spinning of the rotational indicator on tape spools, as seen here:
Here is the code:
// neopixel code
#include <FastLED.h>
#define LED_PIN 5
#define LED_COUNT 14
#define LED_BRIGHTNESS 5 // max 255 which is blinding
#define LED_CENTER_LEFT 0
#define LED_CENTER_RIGHT 7
CRGB leds[LED_COUNT]; // must be lowercase and this variable name or the compilation fails
int LED_LEFT_CENTER = 0;
int LED_RIGHT_CENTER = 7;
int LED_LEFT_MIN = 1; // exclude center LED (left spool)
int LED_LEFT_MAX = 6; // exclude center LED (left spool)
int LED_RIGHT_MIN = 8; // exclude center LED (right spool)
int LED_RIGHT_MAX = 13; // exclude center LED (right spool)
int LED_LEFT_INDEX = random(LED_LEFT_MIN, LED_LEFT_MAX); // index for rotation animations (left spool)
int LED_RIGHT_INDEX = random(LED_RIGHT_MIN, LED_RIGHT_MAX); // index for rotation animations (right spool)
CRGB FOREGROUND_COLOR = CRGB::Black;
CRGB BACKGROUND_COLOR = CRGB::Orange;
CRGB CENTER_COLOR = CRGB::Red;
// function prototypes
void animation_play(int millisDelay = 130); // function prototype to accept optional argument
void animation_rewind(int millisDelay = 50); // function prototype to accept optional argument
// main setup
void setup() {
Serial.begin(9600);
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, LED_COUNT);
FastLED.setBrightness(LED_BRIGHTNESS);
animation_bootup();
// main loop
void loop() {
animation_function_triggered(CRGB::White);
for (int i=0; i < 20; i++) {
animation_pause();
for (int i=0; i < 50; i++) {
animation_play();
for (int i=0; i < 150; i++) {
animation_fastforward();
animation_play();
animation_rewind();
// blink to indicate function triggered
void animation_function_triggered(CRGB color) {
// on
leds[LED_LEFT_CENTER] = color;
leds[LED_RIGHT_CENTER] = color;
FastLED.show();
// sleep
delay(100);
// off
leds[LED_LEFT_CENTER] = CRGB::Black;
leds[LED_RIGHT_CENTER] = CRGB::Black;
FastLED.show();
void animation_pause() {
leds[LED_LEFT_INDEX] = BACKGROUND_COLOR;
leds[LED_RIGHT_INDEX] = BACKGROUND_COLOR;
FastLED.show();
delay(100);
void animation_bootup() {
// illuminate left spool
for (int i = LED_LEFT_MIN; i <= LED_LEFT_MAX; i++) {
if (i == LED_CENTER_LEFT) { continue; }
leds[i] = BACKGROUND_COLOR;
FastLED.show();
delay(50);
// illuminate right spool
for (int i = LED_RIGHT_MIN; i <= LED_RIGHT_MAX; i++) {
if (i == LED_CENTER_RIGHT) { continue; }
FastLED.show();
delay(50);
void animation_fastforward() {
animation_play(40);
// speed is delay, so more is slower
void animation_play(int millisDelay) {
// animation: PLAY (left spool)
if (LED_LEFT_INDEX < LED_LEFT_MAX) {
leds[LED_LEFT_INDEX+1] = FOREGROUND_COLOR;
LED_LEFT_INDEX++;
} else {
leds[LED_LEFT_MAX] = BACKGROUND_COLOR;
leds[LED_LEFT_MIN] = FOREGROUND_COLOR;
LED_LEFT_INDEX = LED_LEFT_MIN;
// animation: PLAY (right spool)
if (LED_RIGHT_INDEX < LED_RIGHT_MAX) {
leds[LED_RIGHT_INDEX+1] = FOREGROUND_COLOR;
LED_RIGHT_INDEX++;
} else {
leds[LED_RIGHT_MAX] = BACKGROUND_COLOR;
leds[LED_RIGHT_MIN] = FOREGROUND_COLOR;
LED_RIGHT_INDEX = LED_RIGHT_MIN;
FastLED.show();
delay(millisDelay);
void animation_rewind(int millisDelay) {
// animation: REWIND (left spool)
if (LED_LEFT_INDEX > LED_LEFT_MIN) {
leds[LED_LEFT_INDEX-1] = FOREGROUND_COLOR;
LED_LEFT_INDEX--;
Serial.println("decrement index");
} else {
leds[LED_LEFT_MIN] = BACKGROUND_COLOR;
leds[LED_LEFT_MAX] = FOREGROUND_COLOR;
LED_LEFT_INDEX = LED_LEFT_MAX;
Serial.println("restart index");
// animation: REWIND (right spool)
if (LED_RIGHT_INDEX > LED_RIGHT_MIN) {
leds[LED_RIGHT_INDEX-1] = FOREGROUND_COLOR;
LED_RIGHT_INDEX--;
} else {
leds[LED_RIGHT_MIN] = BACKGROUND_COLOR;
leds[LED_RIGHT_MAX] = FOREGROUND_COLOR;
LED_RIGHT_INDEX = LED_RIGHT_MAX;
Serial.print("LED_LEFT_INDEX: ");
Serial.print(LED_LEFT_INDEX);
Serial.println();
Serial.print("LED_RIGHT_INDEX: ");
Serial.print(LED_RIGHT_INDEX);
Serial.println();
FastLED.show();
delay(millisDelay);
... and the updated animations:
