TEST-O was at supercon 8. a few people liked him and went home with a copy.
a few built robots remain in stock. if you want a TEST-O, they're sold at the webshop at https://shop.truecontrol.org
code and schematics are available if you want to play around. if you want to build your own instead of buying one, I'll be releasing board files soon. you can also contact me and if you're in the states, I can mail you a blank board and BoM if you want to build it yourself.
I didn't have time to implement i2c slave on any of my badges during supercon 8 - most of which because they needed soft i2c. TEST-O has hard i2c connected and just needs code written. if there's a desire for this - perhaps to change RGB light shows, or to programatically change the modes becuase they are soft selectable - then I can implement it. let me know if this is something you would use.
