Elektor Uno R4 usable for my tests with 328PB
03/20/2017 at 16:18 • 0 commentsSteps taken:
- Use of Elektor Uno R4 board with small modification to use it as 3.3V MCU with 328PB that has 2 HW USARTs.
- Added reset line to RN2483 to solve instable situations for communication.
- Successful test with use of Serial and Serial1 in Arduino sketch for RN2483 communication and debugging via serial console
Details of progress and next steps in main text of project.
Stuck with unstable softserial
03/12/2017 at 14:37 • 0 commentsSteps taken:
- Made test setting to test the serial communication and possible use of timer trigger from RN2483.
- Use of logic analyzer to inspect serial traffic between 328P and RN2483 reveiled strange behavior. It randomly seems to work.
- Retesting with another RN2483 and with a Pro Mini 3.3V 8MHz gave same results.
- Ordered the Atmega328PB chip with 2 hardware UARTs and PCB to solder it on to ensure solid communication, this will impact my board setting.
Connected to the LoRaWAN network on supercaps ;-)
02/23/2017 at 15:19 • 0 commentsAdditional steps taken:
- Configuring the RN2483 via terminal session in order to save settings in EEPROM of device
- Basic sketch to connect to LoRaWAN network using ABP
- Lots of challenges had to be solved
- First couple of successful LoRaWAN transmissions to KPN's network with the board powered by supercaps only
First load test with supercaps only
02/21/2017 at 19:55 • 0 commentsAdditional steps taken:
- Used timer based blink sketch with IDLE sleep mode to test usability of supercaps
- Uptime without solar panel was 65 minutes with every 8 seconds the LED turned on
Promising for further improvement.
Hardware & power optimizations
02/20/2017 at 18:20 • 0 commentsAdditional steps taken:
- Enabled Atmega328P's BOD at 1.8V level to enable usage at 3.3V or lower voltage
- Use of 5V LDO between solar panel and supercaps
- Supercaps in series with 5.4V (only 5V max used) and 5F as result
- Use of 3.3V LDO between solar panel and supercaps
- Test with renewed hardware using a standard blink sketch
Details of progress in main text of project.
Summary of steps
02/16/2017 at 16:35 • 0 commentsHighlight of steps sofar:
- initial hardware setup
- testing with low power settings for ATMega328P
- use of other solar panel and 2 super caps in parallel
