Unmatched Features:
- Large 50mm premium quality pure metal alloy spinner has the weight and feel of real arcade spinners
- Grip pattern on the metal spinner provides ultimate spinner grip eliminating accidental slips
- Perfect fit for left or right hand with curved edges
- Nice balanced weight for great feel and weight for spinner, yet without being too heavy overall
- LCD screen for easy menu driven configuration and real time response
- Powerful Dual-core 133Mhz processor delivering unmatched responsiveness with practically zero lag.
- 2 Large illuminated arcade buttons
- 8 programmable buttons (6 on top, 1 on each side) to set off any of 32 gamepad or 5 common mouse buttons.
- Mouse Emulation including left, right, middle, back and forward buttons
- Analog Gamepad Emulation can emulate left stick, right stick, d-pad, or a rudder control
- Horizontal and Vertical Axis Control with dynamic ability to use both axis during game play! – iCode Exclusive
- Advanced Acceleration settings allow ultimate control depending on spin how fast you spin without losing precision. Game Changing iCode Exclusive Feature!
- Sensitivity Control allows you to control amount of rotation (how much you want to spin) to get from one position to another.
- Combo hot keys that let you dynamically change settings (such as acceleration, sensitivity, emulation modes, and more) in real-time during game play!
- Adjustable Rapid fire option lets to decide how fast rapid fire will work for each button.
- Switch between right and left hand configuration with buttons automatically flipping their actions in Real-time
- Can be easily disassembled for Arcade Cabinet use.
- Supports second spinner (iCode or Arcade1UP) on included logic board (for arcade cabinets)
- USB-C port and wire included
- Built in Bricks mini-game (similar to breakout) with amazing game play directly on the units LCD display
- Easy to update firmware with new capabilities as they become available.
- No batteries required
Compatible with Emulation Station, Retropie, MiSTer, Batocera, Retroarch, and more.
Ali Jani
Alex Cartier
DoctorCharmQuark
svofski
HIGEDARUMA
