Hamming distance maximiser
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 12/23/2025 at 00:110 Comments
A better 3-layers error propagator :
Avalanche from a single-bit error can reach 14, and only one affects only 8. That's a success.
However a whole bunch of inputs (7) still flip only 2 transmitted bits. In order to boost the avalanches there, the encoder should have a cascade too...
So here is the new encoder, with its two cascades to mitigate the poor effect on the line.
Two inputs only affect 4 bits. These can be allocated to the CD and MSB bits.
Notice that from the data available, ALL errors with 1, 2, 3, 5, 12, 13, 14, 15, 16, 17 and 18 bits will flip at least 2 decoded bits.
The whole pipeline is getting insane:
Here is the link, I removed segments to keep the URL working.
Total gates count for the encoder and the decoder : 64 XOR each. That's not insignificant but it's still way "cheaper" than the tens of words of FIFO that it saves, and even though the immediate error latency increases by one or two cycles, the worst cases are considerably reduced, without having to increase the avalanche in the PEAC scrambler.
The worst-case error avalanche has decreased... but it's still manageable and it's a compromise for the size and the input avalanche. I'm sure there are better circuits but it's the best I can do in a day, it's a considerable improvement over the existing system.
And now, VHDL is calling.
