Success
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 12/29/2025 at 17:030 Comments
The Hammer18 circuit fits well inside the NRZI unit and instantly delivers fantastic results. Just as expected. That will be my Christmas then!
Here are the results after 10 millions of injected errors:
 1 : 2241925 - ****************************************************
 2 : 5543183 - ********************************************************************************************************************************
 3 : 1691752 - ****************************************
 4 :  369784 - *********
 5 :  112181 - ***
 6 :   32917 - *
 7 :    6360 - *
 8 :    1401 - *
 9 :     377 - *
10 :      84 - *
11 :      21 - *
12 :      12 - *
13 :       2 - *
14 :       0 -
15 :       0 -
16 :       0 -
17 :       1 - *
The little 1 at the end is an initialisation bug in the program.
Otherwise, the 4x slope is very apparent: the system has achieved true 2-bit-per-word performance!
There is a little "bump" at the start, 1/4 of the errors are caught immediately, but the next cycle catches 1/2! Then every number is divided by 4 as expected.
I'm still unable to explain why the CD bit catches 2× more errors than the other methods, though I'm not sure it matters. However, we have a way to extrapolate the error handling capability.
10 millions (almost 24 bits) give 2 errors at 13 words, 3 more words (4^3=2^6=64) will give about one error in 640 millions (close to 1 billion).
Notes:
In fact I now realise that I have very little clue about the topology of w18. I'm taking care of this at 181. PEAC w18.
And I still need to fix this tiny little bug in the program, that leaves one uncaught error. I didn't notice it before because I always got many leftovers but that bug still appears with no NRZ or Hamming avalanche, even after thousands of cycles : my test code must have a problem somewhere.
And it's a weird issue with something that does not clear a register somewhere, it's taken care of by double-resetting the circuit, 2 clocks seems to solve it but what and where... ?
But at least I can get clean outputs:
100 errors:
 1 :     23 - ***********************
 2 :     61 - *************************************************************
 3 :     13 - *************
 4 :      0 -
 5 :      3 - ***
1000 errors:
 1 :    229 - ********************************
 2 :    582 - ********************************************************************************
 3 :    154 - **********************
 4 :     23 - ****
 5 :      8 - **
 6 :      3 - *
 7 :      1 - *
10K errors
 1 :   2236 - ********************************
 2 :   5625 - ********************************************************************************
 3 :   1635 - ************************
 4 :    351 - *****
 5 :    108 - **
 6 :     31 - *
 7 :     11 - *
 8 :      3 - *
100K errors:
 1 :  22343 - *********************************
 2 :  55555 - ********************************************************************************
 3 :  16765 - *************************
 4 :   3771 - ******
 5 :   1121 - **
 6 :    348 - *
 7 :     79 - *
 8 :     14 - *
 9 :      2 - *
10 :      1 - *
11 :      1 - *
1M errors:
 1 : 223252 - *********************************
 2 : 554817 - ********************************************************************************
 3 : 169397 - *************************
 4 :  37354 - ******
 5 :  11003 - **
 6 :   3274 - *
 7 :    701 - *
 8 :    151 - *
 9 :     40 - *
10 :      8 - *
11 :      3 - *
10 millions:
     1 : 2231957 - *********************************
     2 : 5546325 - ********************************************************************************
     3 : 1695563 - *************************
     4 : 371915 - ******
     5 : 112766 - **
     6 :  33113 - *
     7 :   6437 - *
     8 :   1426 - *
     9 :    369 - *
    10 :     98 - *
    11 :     24 - *
    12 :      3 - *
    13 :      2 - *
    14 :      2 - *
len:1 CD0:138 CD1:6449726 Err:3550136 Missed:0 Ham:1 NoNRZI:0
The progress 5, 7, 8, 11, 11, 14 has some hicups... Maybe the PRNG is not random enough?
Anyway, it is great to finally get rid of the "long tail"! Look at this amazingly compliant logplot!
The 10M slope converges to 15, thus 16 words would be good for 100M. High-safety protocols would still work with 16-word buffers but keep the last one in quarantine too.
And here is another logplot that compares the slope versus the number of (consecutive) flipped bits.
Get it there : miniMAC_2026_20251230.tbz
