Double parity
A project log for Not an Ethernet Transceiver
incompatible custom(izable) circuit for sending fast data over twisted pairs
yann-guidon-ygdesYann Guidon / YGDES 2 days ago0 Comments
The format is now set to 20-bit frames that contain 16 bits. The overhead is 25% like 100BaseT but with increased error detection and wander reduction.
The 16 bits are processed with PEAC16, as per the diagram below
A different PEAC flavour is under consideration but the principle remains the same : the 16 bits (d0..d15) are extended to 18, with the extra 2 bits as markers (m0, m1).
2 more bits (p0, p1) are added as even parities : that's a total of 20 bits.
The key property of PEAC is that the whole message can  never be all-0 or all-1.
In any case, m+d always have at least 1 bit set and 1 bit cleared.
The parity bits ensure that the whole frame has a "Return To Neutral" behaviour, though it does not remove all wander.
There are 2 parity bits, so 2 choices depending on the m+d parity:
One approach to reduce wander is to "break" long strings of identical values when they are +1 or -1. The parities are placed at 1/4th and 3/4th of the frame for maximum reach, as well as overlap with the previous and next words. It is important to provide a strong, strict bound on the maximum run length of 0s.
The parity bits are checked by the receiver but the actual parity pattern is a degree of freedom chosen by the encoder to reduce wander. It is there to provide a garantee that at least 2 transitions will occur in each frame.
