Bidirectional pipeline
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 04/09/2025 at 00:400 Comments
If the Parpop and PEAC units can be bidirectional then they can be shared between the sender and receiver channel, if the speed allows it.
For a 50MHz PEAC unit (a pretty conservative speed in FPGA), the unit pumps one word per 20ns, then the multiplexing halves the speed down to 25MHz but that's still 25×20=500Mbps in both directions. And there is some margin !
What does it look like ?
Both units have their output pipelined, and inputs have a single multiplexer. This is a reasonable overhead though the PEAC unit needs 2 sets of work registers, to alternate the functions. It's still less than a full register set...
Scheduling is rather simple, at least with the simple version of PEAC :
  1. First phase, PEAC scrambles data for the transmitter and the ParPop flips the received data
  2. Second phase, PEAC descrambles the received data while ParPop encodes the data to send.
Both units are working all the time, on different data, it's far from a complex FSM.
Yet, using a specialised unit for each function is simpler, so multiplexing is beneficial when resources are really constrained, and when DFF are not expensive (as in a small FPGA). A full custom chip will need some prototyping and comparisons, since the extra MUX and control logic can easily compensate the surface reduction of using only 2 units instead of 4.
