Better stats
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 05/17/2025 at 08:020 Comments
Going back to the data collected so far with PEAC16, I did some adjustments to get this graph:
This is the rate (in %) of errors missed by the GrayPar unit, depending on the error burst's length.
So the peaks of misses are around 33% at 6, 12 and 17.
Burst lengths 1 to 4 and 8 to 10 are below 12.5%.
13-14-15 are not bad either.
I also traced the adjusted rates of error discovery at the PEAC level:
so "most" of the errors are indeed found after 8 cycles but that is still not a guarantee. An adaptive algorithm is required for the retransmission, to move the retransmit window and compare previous data, looking for whether they match.
