Architecture (summer edition)
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 07/09/2025 at 15:220 Comments
This project originally was meant to be a simple, standalone circuit but now the system contains 3 modules :
It is modular and provides some sort of plug-in replacement/evolution, but mostly it decouples the development so I can work on all 3 aspects in parallel.
The interfaces are :
I have removed the "asymmetrical" configuration for 4 pairs, as it makes it uselessly complex.
But there is still no autosense of each pair's direction. Some inversion will have to be done at the socket level, probably mechanically. Since cables won't be changed often, it's possible that the AFE-Jack modules can be interchangeable and swapped from one end of the cable to the other. Hence the need for standardisation too : the AFE must plug everywhere.
Or I find a way to swap the jack's polarity, mechanically, such that all the Cat5 cables are "straight".
