GrayPar18: 5+5+5+3
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 10/27/2025 at 02:190 Comments
Some new circuiting on CircuitJS...
The 15 data bits are "pretty shallow" on the receiver end, with only 2 XORs of latency.
However the 3 MSB must be mixed with a pretty sophisticated 6->3 LUT. XORs won't cut it.
A good LUT prevents "cancellations" of multi-bit events.
However the 6 cascades are pretty short and there is very little avalanche... Maybe 8+8+2 is more efficient ?
