Meanwhile: Koopman
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 11/03/2025 at 03:330 Comments
Philip Koopman is a fantastic resource concerning everything safety, reliability, CRCs, checksums, about which he indeed wrote a book recently. And some FORTH of course. Never forget FORTH.
I contacted him about PEAC in October 2022, asking for help/validation of PEAC16x2. My article was in kiosks for more than a month already (and it's now in Creative Commons so you can read it online as you like). He could not help me, as he was busy with "work on autonomous vehicle safety".
Lately, looking back at his blog, I see that I missed a few things these last years, not just his book (which I'm very curious to get but I won't use Amazon).
That's right: he has invented and released his own checksum, claiming better than HD3 (that is: detecting all error made of 1, 2 or 3 bits).
I'll have to find the value(s) of k.
No idea if he ever has somehow looked at my article but he published his own paper and the curves look nice.
https://arxiv.org/abs/2304.13496
http://checksumcrc.blogspot.com/2023/05/koopman-checksum.html
http://checksumcrc.blogspot.com/2024/02/comparative-speeds-for-different.html
http://checksumcrc.blogspot.com/2024/03/why-to-avoid-hash-algorithms-if-what.html
So what's the deal here?
From my perspective it looks like some Adler where the second register is replaced by a shift.
But WHY A SHIFT and not at least a rotation ? Part of the reason may be with the modulus which "recycles" the bits that would have been thrown away by the left shift. The k parameter alone might account for the HD1 bump compared to the "Modular Single-Sum Checksum" it is derived from. 65371 is a nice prime number with a good binary pattern.
Apart from providing a new class of algorithms that is somewhat better (HD-wise) than the classic Fletcher, Adler and such, without a crazy increase of computation time, I am more curious than blown away.
Now, to address the last concern, there is something else that is interesting: a parity mode. I reinvented it these last months but it seems new to me in the literature. Quoting:
·     DualX-32P: This is DualX-32 with 15-bit modulus of 32749 and an additional parity computation. The parity computation boosts fault detection to HD=4 while still being faster than DualSum-32.
·     Koopman-32P: This uses a 64-bit sum variable with a modulus of 0x7FFFFFED, processing the data word one 32-bit block at a time. This is slightly slower than Koopman-32 due to an extra XOR operation with an additional parity register inside the inner loop that is used to compute parity.
Going to HD4 is cool, at the expense of one data bit per word (or so, I'll have to double-check). Here, I'm doing (rediscovering) something similar by using the high bit (that should remain 0 even with random data) for an extra (out-of-band) data.
Now, let's not forget the different approaches and goals. Philip Koopman addresses the classic checksum case, where the data blocks are bare bytestreams that need to be preserved, in case of random access for examination. It could be in HW or SW.
In this project,
So the parity bits play a big role here: sure they eat up some bandwidth (12.5% overhead) but they provide the desired certainty.
So my design might appear over-engineered and very conservative but I want to achieve very high reliability despite cheap/subpar physical/analog circuits. Adding a checksum every kilobyte wouldn't cut it. And I don't know where Koopman's own rabbithole goes to, but I understand we diverge at some point.
Anyway, his design is quite funky :-)
