gPEAC circuit correction
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 11/12/2025 at 06:090 Comments
The last log 101. gPEAC: the circuit has a little flaw...
Test.
Test early.
Test often.
Some tests have reminded the importance of the carry and the updated algorithm is
Phase0:    accumulation
  X[18:0] := Msg[17:0] + Y[17:0] + X[18]
  Y[18:0] :=   X[17:0] + Y[17:0] + Y[18]
Phase1:    modulo
  t[18:0] := X[18:0] + Cst
  u[18:0] := Y[18:0] + Cst
  X[18]:=t[18]
  if t[18]==1, X[17:0]=t[17:0]
  Y[18]:=u[18]
  if u[18]==1, Y[17:0]=u[17:0]
so the carry still exists as the MSB of X and Y, which is always written and selectively used, depending on the phase.
Thus the requirement/format for the adder is : 19 bits with carry input (still no carry out, it's the MSB).
The diagram is updated:
Fortunately, the implementation has only been in high level so far, indeed to verify the long-term behaviour. Without this carry, the cycles are very short.
Another big problem :
The system loops after 32.315.302.423 iterations only !
The modulus is maximal but not perfect !
