As I try to find the best permutations in C, the tiles need to be emulated as well, and I have come up with this C code, optimised for speed on recent OOO CPUs:
static inline unsigned int Encode_layer(unsigned int X) {
// inversions
unsigned int Y = (X & 0x02010) * 30;
// Gray encoding
unsigned int G = (X & 0x03C1E) >> 1;
return X ^ Y ^ G ;
static inline unsigned int Decode_layer(unsigned int X) {
unsigned int
Y = X & 0x02010,
A = (Y ) >> 4,
B = (X & 0x03018) >> 3;
Y = Y*30;
A ^= (X & 0x0381C) >> 2;
B ^= (X & 0x03C1E) >> 1;
return X ^ Y ^ A ^ B;
I process both 9-bit "tiles" at once, in the same word (SWAR approach).
For each tile, bits 5-9 are inverted by bit 4, and bits 0-4 are a Gray cascade.
Optimising the permutation was a different story and I opted to allocate 3MB of L3 cache...
.. (typingtypingtypingtypingtypingtypingtypingtyping)
And I was dubious but I got some pretty impressive results. The top ones so far look like this, after the 3rd layer :
min Encoder Decoder
sum sum max min sum max min permutation #s
5 99 15 2 165 18 3 1663:1314
5 99 15 2 165 18 3 1672:1476
5 99 15 2 165 18 3 1825:1323
5 99 15 2 165 18 3 1834:1485
5 100 12 2 118 11 3 1087:1380
5 100 12 2 118 11 3 1096:1542
5 100 12 2 118 11 3 1249:1371
5 100 12 2 118 11 3 1258:1533
5 101 14 1 145 14 4 201:1353
5 101 14 1 145 14 4 210:1515
5 101 14 1 145 14 4 39:1362
5 101 14 1 145 14 4 48:1524
5 101 14 1 159 12 4 201:1362
5 101 14 1 159 12 4 210:1524
5 101 14 1 159 12 4 39:1353
5 101 14 1 159 12 4 48:1515
5 102 11 2 120 10 3 476: 108
5 102 11 2 120 10 3 485: 270
5 102 11 2 120 10 3 638: 117
5 102 11 2 120 10 3 647: 279
- All of these have a sum of minimum of the avalanche = 5 : either 2 and 3 or 1 and 4
- Both encoder and decoder have a sum of avalanches > 100, sometimes reaching 159...
- The maximum of an individual avalanche is in the 10-14 range
So far I have a good set of criteria to filter further brute-forcing for the 4th layer (3rd permutation). And I have optimised the heck out of it so it produces these results in under 1 second, so the further tests will take only like 20 minutes...
And if I'm patient enough I can relax the thresholds to find more interesting and better behaving configurations.
And it seems that 4 layers could be enough after all :-)
Adding the 3rd permutation, I get these results:
Min Encoder Decoder Sum Sum Max Min Sum Max Min Perm. numbers 12 127 13 3 200 14 9 1663:1482:1458 12 127 13 3 200 14 9 1672:1320:1467 12 127 13 3 200 14 9 1825:1491:1296 12 127 13 3 200 14 9 1834:1329:1305 12 130 12 3 196 17 9 669:1154: 386 12 130 12 3 196 17 9 678: 992: 395 12 130 12 3 196 17 9 831:1163: 548 12 130 12 3 196 17 9 840:1001: 557 12 99 10 2 203 15 10 218:1241:1478 12 99 10 2 203 15 10 227:1079:1487 12 99 10 2 203 15 10 56:1232:1316 12 99 10 2 203 15 10 65:1070:1325
The decoder gets impressive avalanche but the encoder doesn't take off :-/ the minimum avalanche doesn't get above 3...
Which is explained by a bug in the code ...
And with the stupid bug found, here it goes:
13 148 12 5 172 13 8 - 1646:1465:1157 13 148 12 5 172 13 8 - 1655:1303:1166 13 148 12 5 172 13 8 - 1808:1474: 995 13 148 12 5 172 13 8 - 1817:1312:1004 13 148 12 5 184 13 8 - 1646:1465:1166 13 148 12 5 184 13 8 - 1655:1303:1157 13 148 12 5 184 13 8 - 1808:1474:1004 13 148 12 5 184 13 8 - 1817:1312: 995 13 177 13 8 127 10 5 - 1425:1705: 762 13 177 13 8 127 10 5 - 1434:1867: 771 13 177 13 8 127 10 5 - 1587:1696: 924 13 177 13 8 127 10 5 - 1596:1858: 933 13 178 12 8 149 13 5 - 1730: 30:1314 13 178 12 8 149 13 5 - 1739: 192:1323 13 178 12 8 149 13 5 - 1892: 21:1476 13 178 12 8 149 13 5 - 1901: 183:1485 13 195 14 7 150 11 6 - 1731: 854:1016 13 195 14 7 150 11 6 - 1740: 692:1025 13 195 14 7 150 11 6 - 1893: 863:1178 13 195 14 7 150 11 6 - 1902: 701:1187 13 196 15 7 156 11 6 - 398:1847:1353 13 196 15 7 156 11 6 - 407:1685:1362 13 196 15 7 156 11 6 - 560:1838:1515 13 196 15 7 156 11 6 - 569:1676:1524
I expected a slightly higher minimal score, but if a particular behaviour is needed, on the send or the receive side, then we can select a score of 8 at the cost of "only" 5 on the other side.
But these results are actually excellent, in fact. So here is the dump of the four sets of permutations (highlighted above).
Dumping permutations: Perm398 = forward( 6 16 8 3 7 1 17 11 12 15 5 13 0 14 2 4 10 9 ) reverse( 12 5 14 3 15 10 0 4 2 17 16 7 8 11 13 9 1 6 ) Perm1847 = forward( 17 2 9 0 16 6 11 7 8 4 1 12 3 5 15 10 14 13 ) reverse( 3 10 1 12 9 13 5 7 8 2 15 6 11 17 16 14 4 0 ) Perm1353 = forward( 10 1 12 9 5 6 2 7 15 13 4 11 14 0 17 3 16 8 ) reverse( 13 1 6 15 10 4 5 7 17 3 0 11 2 9 12 8 16 14 ) Dumping permutations: Perm407 = forward( 15 7 17 12 16 10 8 2 3 6 14 4 9 5 11 13 1 0 ) reverse( 17 16 7 8 11 13 9 1 6 12 5 14 3 15 10 0 4 2 ) Perm1685 = forward( 4 1 12 3 5 15 10 14 13 17 2 9 0 16 6 11 7 8 ) reverse( 12 1 10 3 0 4 14 16 17 11 6 15 2 8 7 5 13 9 ) Perm1362 = forward( 1 10 3 0 14 15 11 16 6 4 13 2 5 9 8 12 7 17 ) reverse( 3 0 11 2 9 12 8 16 14 13 1 6 15 10 4 5 7 17 ) Dumping permutations: Perm560 = forward( 15 5 13 0 14 2 4 10 9 6 16 8 3 7 1 17 11 12 ) reverse( 3 14 5 12 6 1 9 13 11 8 7 16 17 2 4 0 10 15 ) Perm1838 = forward( 8 11 0 9 7 15 2 16 17 13 10 3 12 14 6 1 5 4 ) reverse( 2 15 6 11 17 16 14 4 0 3 10 1 12 9 13 5 7 8 ) Perm1515 = forward( 13 4 11 14 0 17 3 16 8 10 1 12 9 5 6 2 7 15 ) reverse( 4 10 15 6 1 13 14 16 8 12 9 2 11 0 3 17 7 5 ) Dumping permutations: Perm569 = forward( 6 14 4 9 5 11 13 1 0 15 7 17 12 16 10 8 2 3 ) reverse( 8 7 16 17 2 4 0 10 15 3 14 5 12 6 1 9 13 11 ) Perm1676 = forward( 13 10 3 12 14 6 1 5 4 8 11 0 9 7 15 2 16 17 ) reverse( 11 6 15 2 8 7 5 13 9 12 1 10 3 0 4 14 16 17 ) Perm1524 = forward( 4 13 2 5 9 8 12 7 17 1 10 3 0 14 15 11 16 6 ) reverse( 12 9 2 11 0 3 17 7 5 4 10 15 6 1 13 14 16 8 )
By altering the Galois sequences (some permutations here and there), more results are obtained. So far, I haven't found better scores. I'll continue a bit, then try another approach.
Note : all "hits" go in quartets, I don't know yet why, but we find the same deltas : 9 between a pair of results and 171 between extremes... at least for the permutation number of the 1st level.
Source code is there : PermParam_20251226.tgz
Quadrupling the number of sequences, using xors (that do some swap actually), I get this one:
14 169 188 14 6 14 8 - 840 812 5745 Perm840 = forward( 2 7 0 6 9 1 15 13 12 3 16 5 17 14 4 8 10 11 ) reverse( 2 5 0 9 14 11 3 1 15 4 16 17 8 7 13 6 10 12 ) Perm812 = forward( 1 10 15 8 14 17 9 5 3 2 11 6 13 7 4 12 16 0 ) reverse( 17 0 9 8 14 7 11 13 3 6 1 10 15 12 4 2 16 5 ) Perm5745 = forward( 14 1 8 10 0 5 15 16 12 13 6 11 17 9 2 4 3 7 ) reverse( 4 1 14 16 15 5 10 17 2 13 3 11 8 9 0 6 7 12 )
It's imbalanced but still looks nice.
- Encoder avalanche: between 6 and 14
- Decoder avalanche : between 8 and 14
- 188/18 > 10 (> 9)
This is achieved by expanding the Galois sequences with XOR by a number (between 1 and 3) to create alternate versions. I get 7776 sequences, more opportunities for cross-checking and finding happy numerical accidents.
There is also the balanced ones:
14 188 168 14 7 14 7 - 1965 7515 4021 14 188 168 14 7 14 7 - 1974 7677 4030 14 188 168 14 7 14 7 - 2127 7506 4183 14 188 168 14 7 14 7 - 2136 7668 4192 Perm1965 = forward( 3 5 9 17 16 10 15 12 1 2 0 14 6 7 13 8 11 4 ) reverse( 10 8 9 0 17 1 12 13 15 2 5 16 7 14 11 6 4 3 ) Perm7515 = forward( 17 2 11 0 6 16 8 9 10 14 1 7 13 15 5 12 4 3 ) reverse( 3 10 1 17 16 14 4 11 6 7 8 2 15 12 9 13 5 0 ) Perm4021 = forward( 4 17 6 5 1 15 7 14 16 13 0 9 10 8 12 2 3 11 ) reverse( 10 4 15 16 0 3 2 6 13 11 12 17 14 9 7 5 8 1 ) Perm1974 = forward( 12 14 0 8 7 1 6 3 10 11 9 5 15 16 4 17 2 13 ) reverse( 2 5 16 7 14 11 6 4 3 10 8 9 0 17 1 12 13 15 ) Perm7677 = forward( 14 1 7 13 15 5 12 4 3 17 2 11 0 6 16 8 9 10 ) reverse( 12 1 10 8 7 5 13 2 15 16 17 11 6 3 0 4 14 9 ) Perm4030 = forward( 13 8 15 14 10 6 16 5 7 4 9 0 1 17 3 11 12 2 ) reverse( 11 12 17 14 9 7 5 8 1 10 4 15 16 0 3 2 6 13 ) Perm2127 = forward( 2 0 14 6 7 13 8 11 4 3 5 9 17 16 10 15 12 1 ) reverse( 1 17 0 9 8 10 3 4 6 11 14 7 16 5 2 15 13 12 ) Perm7506 = forward( 8 11 2 9 15 7 17 0 1 5 10 16 4 6 14 3 13 12 ) reverse( 7 8 2 15 12 9 13 5 0 3 10 1 17 16 14 4 11 6 ) Perm4183 = forward( 13 0 9 10 8 12 2 3 11 4 17 6 5 1 15 7 14 16 ) reverse( 1 13 6 7 9 12 11 15 4 2 3 8 5 0 16 14 17 10 )
And now I understand why I get these deltas of 9 : the permutations are identical, rotated/offset by 9 because the tiles are symmetrical too, so the whole permutations are +9 everywhere... It's obvious from Perm1965 vs Perm1974.
Yann Guidon / YGDES
