An article describing the Hammer will soon be published in the French "Hackable" magazine.
But I must reorient my priorities at this moment, as I must prepare the upcoming March tapeout of TinyTapeout#26 ...
The transceiver is far from ready and I must also focus heavily on #miniPHY : real-life tests are planned for the end of the month as well. Which made me drift toward low-voltage pulse generation with avalanche through Germanium transistors...
20260304:
The article is available!
Distance de Hamming maximale : la clé de la détection d’erreurs
Hackable n°65 / mars 2026
Yann Guidon / YGDES
