1Basic Assembly Instructions
- Before installing the 18 LEDs the small "back" mirror needs to be placed in the center of the pattern of holed for mounting the LEDs.
- Bend the leads on each LED 90 degrees and place the LED on top of the mirror. The LEDS will capture the back mirror in place.
- After all of the LEDS and the resistor are soldered to the board the "front" mirror can be placed in the bezel followed by the populated PCB. The circuit board will snap into place capturing the front mirror.
