1Step 1
Collect the needed Materials (See above)
2Step 2
Solder enameled copper wire to the selected LEDs
3Step 3
Prepare a control PCB (Maybe you want to google Bare Bone Arduino), Flash the Programm to the Controller.
4Step 4
Add the Series Resistors to the PCB. You may want to calculate the correct Values. For Green LEDs @ 5V 100 Ohm are okay.
5Step 5
Test the Assemblies
6Step 6
(hot) glue the LEDs to the Crystal Cluster. (..)
7Step 7
Drill a hole into the planting hole to let the cable out. If you don't care you can also run the cable over the edge of the pot
8Step 8
Burry everything into a planting pot. I would recommend planting clay. If you want to use soil, you might take further preservations of the electronics.
9Step 9
Connect Power and enjoy your artificial Tiberium Cluster
