Alpha Groot
I am Groot
I am Groot
I am Groot
  • I am Groot
    MasterOfNull11/28/2024 at 07:14 0 comments
    Project on hold pending static backpressure testing with new compressor type fan for inflating the body.
    The existing fan *almost* does it.
    Yes, we are inflating the body.  Yes I have pictures.
    We got as far as placing the chest and abdomen foam panels before I decided we should go a little higher on the pressure in the body.
    Stay tuned.
  • I am Groot
    MasterOfNull10/26/2024 at 07:11 0 comments
    Treetacle testing proceeded today.
    Tree failures and one success.
    The first two twigs failed by being too leaky so we had a bad case of limp stick syndrome.
    The third one survived long enough to pull itself apart through the fabric at the seam.
    The fourth stick got sealed by heat seaming.
    I improvised to see if this would work by dragging the tip of a hot melt glue gun through the material, and then I sewed through that. It worked.
    Cleaned up and I'm coming back tomorrow.
    This is it...
  • I am Groot
    MasterOfNull10/23/2024 at 18:42 0 comments
    I'll give you a hint.
  • I am Groot
    MasterOfNull10/22/2024 at 17:02 0 comments
    It's Oct 22nd, 2024 and Groot is going to come out to play.
    He is going to need some help for something special I have planned.
    You're going to like this.
View all 4 project logs
