I am Groot
11/28/2024 at 07:14 • 0 commentsProject on hold pending static backpressure testing with new compressor type fan for inflating the body.
The existing fan *almost* does it.
Yes, we are inflating the body. Yes I have pictures.
We got as far as placing the chest and abdomen foam panels before I decided we should go a little higher on the pressure in the body.
Stay tuned.
I am Groot
10/26/2024 at 07:11 • 0 commentsTreetacle testing proceeded today.
Tree failures and one success.
The first two twigs failed by being too leaky so we had a bad case of limp stick syndrome.
The third one survived long enough to pull itself apart through the fabric at the seam.
The fourth stick got sealed by heat seaming.
I improvised to see if this would work by dragging the tip of a hot melt glue gun through the material, and then I sewed through that. It worked.
Cleaned up and I'm coming back tomorrow.
This is it... -
I am Groot
10/23/2024 at 18:42 • 0 commentsI'll give you a hint.
I am Groot
10/22/2024 at 17:02 • 0 commentsIt's Oct 22nd, 2024 and Groot is going to come out to play.
He is going to need some help for something special I have planned.
You're going to like this.
MasterOfNull
