Treetacle testing proceeded today.
Tree failures and one success.
The first two twigs failed by being too leaky so we had a bad case of limp stick syndrome.
The third one survived long enough to pull itself apart through the fabric at the seam.
The fourth stick got sealed by heat seaming.
I improvised to see if this would work by dragging the tip of a hot melt glue gun through the material, and then I sewed through that. It worked.
Cleaned up and I'm coming back tomorrow.
This is it...
