v3 Final_Final SAO
For v3, we updated the artwork a bit and including some better power handling for the USB vs Supplied Badge power. Now, the SAO will take power from which ever source has the highest voltage. So you can safely leave the USB power plugged in as well as supplying power from the badge.
Otherwise, features, pins, and functionality remains the same as v2
