Features
(This list is mirrored from roadmap.md in the GitHub repository)
Core functionality
- Display time remaining in each tank
- Swtich active tank (including crossfeed)
- Pre-flight programming state allowing at least configuration of time in each tank
- Start flight action
- End flight action (to prevent warning features tripping)
- Keep accurate time and state across loss of main power and reset.
Nice to haves
- Display elapsed flight time
- Display elapsed time on current tank
- Show elapsed time vs. reserve time vs. total remaining time
- Show use of reserve time differently visually (more urgent)
- Display flight start time
- Protect against accidental changes to tank quantity
- Automatic fuel balancing - alter user configured fuel change time in flight to balance fuel in tanks.
- Sleep between updates to save power? We only need to be awake to update the screen every few seconds during a flight.
- Alert sound loud enough to be heard in the cockpit:
- short chirp to indicate it's time to switch tanks, or time is overdue
- a more worrying alert to notify entering reserve time, plus a repeated alert every five or ten minutes to remind the pilot of the status.
- persistent alarm should sound when running dangerously low on tank time or on total remaining flight time. For tank time where there is adequete fuel remaining in the other tank, the alarm may not be dismissable. For other cases, the persistent alarm may be silenced to a chirp every minute.
- Configure fuel change time
- Configure date and time
- Display time in UTC
- SAR time monitoring with audible warnings to update/terminate (active even outside of flight mode)
Other (probably feature creep)
- Multiple count up/down timers for navigation
- Scroll through log of fuel changes this flight
- Log previous flights (duration), aircraft registration / "totals flight log"
- Allow entering fuel quantities and have the program work out the time per tank. At minimum, this could be a single screen where instead of configuring time for two tanks, you config quantity in each tank, plus burn per hour and unusable fuel. The burn per hour and unusable could be recalled from EEPROM.
- Low power mode where the user has to wake with an interupt to see the display for five seconds at a time. could show time remaining in current tank/flight, or some configurable value.
Stephen Holdaway
Darian Johnson
David Truong
I ran across this site by accident. I have been trying to build such a device for a long time. Given that fuel exhaustion is the leading cause of engine stoppage, it is surprising we don't have something in the market. The timers that Sporty's and ASA sell are don't do the job because they are not LED (hard to see), and they don't sound any alarms. What I would like to see is a simple but bright countdown timer (minutes, not seconds), and would starting making a lot of noise and flash lights when you get below a certain threshold.
