Hackaday.io Hackaday.io
Sign up Log in
SAO Bread Board Adapter
Simple adapter from SAO connector to solderless breadboard
(Single sided PCB)
scorch-worksScorch Works
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
7 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
261
0
7
7
Team (1)
  • scorch-worksScorch Works
Join this project's team
completed project
hardware
Related lists
Simple Add-on badges
SAO / Simple Add-on badges. Message me if you think I've missed one to add.
This project was created on 10/27/2024 and last updated 2 years ago.
Description
Simple adapter from SAO connector to solderless breadboard. The design is a single sided PCB that is also compatible with protoboards like the one shown in the images from Digi Key. This was inspired by Ben Combee's Breadboard SAO contest entry. I liked the idea of getting a breadboard on the SAO connector. I was doing this quick and dirty so the Gcode was actually generated using a black and white image of the traces.
Files
This is the image I used to create the G-Code. No GERBERS were made.
Portable Network Graphics (PNG) - 31.29 kB - 10/27/2024 at 03:55
Preview
SAO_ADAPTER_ALL.ngc
G-code to create the board on a CNC mill. Put a .020" end mill in the machine. Zero the Z axis on the top of the copper and let it rip at 30,000 RPM.
ngc - 17.10 kB - 10/27/2024 at 03:54
Download
Project Logs
Collapse
  • Made a few
    Scorch Works • 10/29/2024 at 00:15 • 0 comments
    I made a few of these adapters while I was waiting for my infinity mirror SAO boards to arrive.
View project log
Log In/Sign up to comment
Sign up with Github
OR
I made a tool that converts an image into multiple PCB layers - pixel brightness to board opacity. (for use with Eagle)
Project Owner Contributor
PCB - Art medium
alongrussalongruss
DIY PCB – How To Create Your Own Printed Circuit Boards
DIY PCB - How To Create Your Printed Circuit Board
pcb-designerPCB designer
How to build a simple FPV monitor at home for under $40.
DIY Homemade FPV Monitor
michael-delaneyMichael Delaney
Made a Tiny Skyrim Quest Marker using PCBs, Setup is powered by an Attiny13A Microcontroller.
Skyrim Quest Marker
arnov-sharmaArnov Sharma
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SAO Bread Board Adapter", please tell us the reason.
Send message
Remove Member
