Q8bot is a a miniature, dynamic quadruped robot. It is designed to have ZERO wires and cables - everything is directly plugged into the center PCB, greatly reducing complexity, weight, and cost.
The current bill of materials (BOM) starts at around $300 dollars, depending on your fabrication capability. It is now fully open source, and all design files and code can be accessed through the GitHub repository.
