1Print the required parts
Print all required parts. A print profile is available for bamboolab printers on makerworld, and the stl files are available for any other printer.
2Install magnets
All magnets should be installed in the same orientation! This includes the pen. When the pen is "floating" in its stand, all the magnets poles are pointing the same way.
Start with the stand. Each slot in the ring holds 5 magnets.
3 Magnets go in the contact pad (center of the ring).
The pen cap contains the 3mmx2mm magnet in the tip, and 10 magnets in the core.
3Glueup
This project was designed to minimize glue, but I still recommend using some super glue to hold the pen2 part (the connector ring) onto the pen1 part (the magnet carrier). This keeps the magnets in place and helps the pen snap into its cap.
Nianzu
