None-Position Rope Type Water Leak Sensor
It is sensitive to leaks anywhere on the cable, instantly detecting and reporting water drops via LoRaWAN®.
Public Chat
Starting from
$22.90
Makerfabs has 1455 orders / 36reviews
Ships from China
The AgroSense LoRaWAN® Rope-Type Water Leak Sensor detects water or oil leaks along the entire sensor cable. It instantly reports water drops via LoRaWAN® from any point on the cable, making it ideal for garage and kitchen leak detection.
Powered by LoRaWAN®, it offers reliable, long-range communication with low power consumption. Unlike wired systems, this battery-powered sensor simplifies deployment and reduces complexity. End-users can easily configure the device through a cloud server, streamlining setup and management. Perfect for efficient, scalable leak detection in various environments.
Detection typesVarious liquids such as water, oil, etc.
Detection modesRange detection
Wireless Parameters:
Communication ProtocolStandard LoRaWAN® protocol 1.0.3
Network Access/Operating ModeOTAA Class A
MAX Transmit Power21dBm
Receiver Sensitivity-137dBm/125kHz SF=12
Frequency BandEU868/US915
Physical Parameters:
Sensor cable Length/Range2.0m(support customizing)
Power Supply2 x AAA 1.5V batteries
Operating Temperature-40°C ~85°C
Protection ClassIP68
Dimensions131 × 62.7 × 27.5 mm
MountingWall Mounting
View all 3 project logs
  • 1
    Step 1
    This none position rope-type water leak sensor is ideal for environments requiring real-time water leak detection, such as basements, server rooms, warehouses, and large equipment areas. Its rope design covers a wide area, accurately detecting leaks and ensuring timely detection to minimize property damage and equipment failure risks.
View all instructions
Makerfabs wrote 11/05/2024 at 07:45 point
The Rope-Type Water Leak Sensor is designed for use in environments where water or oil leakage detection is critical. Thanks to its support for the LoRaWAN® protocol and ultra-low power consumption, it is ideal for remote or hard-to-reach locations. such as:
Basements and Crawl Spaces: Detect leaks in areas prone to water accumulation.
Warehouses and Storage Facilities: Protect sensitive equipment from water damage.
Data Centers: Ensure early detection of water leaks around critical server infrastructure.
Factories and Manufacturing Plants: Monitor for leaks in equipment or pipes in large industrial settings.
Residential Applications: Use in kitchens, bathrooms, or basements to prevent water damage.
