STM32F412 Discovery Kit Overview
Specifications and Features:
- STM32F412ZGT6 microcontroller with 1 Mbyte of Flash memory and 256 Kbytes of RAM, in an LQFP144 package
- 1.54-inch 240×240 pixel TFT color LCD with parallel interface and capacitive touch panel
- USB OTG FS
- I2S audio codec
- Stereo digital ST-MEMS microphones
- 128-Mbit Quad-SPI NOR Flash memory
- Reset push-button and joystick
Use Cases:
- Examples of using the STM32F412, such as IoT projects, sensor control, and real-time data processing.
STEP 1: Preparing Your STM32F412 for CircuitPython
https://circuitpython.org/board/stm32f412zg_discovery/
Installing CircuitPython:
- Download the CircuitPython firmware for STM32F412 from https://circuitpython.org/board/stm32f412zg_discovery/
- Download the STM32 ST-LINK Utility from https://www.st.com/en/development-tools/stsw-link004.html
- Use the STM32 ST-LINK Utility to flash the CircuitPython firmware onto the STM32F412 board.
Verifying the Connection:
After flashing the firmware, the connection will be verified, and you will find the "CIRCUITPY" drive (G:), indicating the process is complete.
STEP 2: Getting Started with CircuitPython on STM32F412
Writing Your First Code in CircuitPython:
- Guide on creating a code.py file in the CIRCUITPY drive.
- Simple code example, such as blinking an LED or displaying a message on the Serial Monitor.
- How to run the code and check the results.
Using CircuitPython Libraries on STM32F412:
- Introduce useful libraries, such as Adafruit Blinka (which enables CircuitPython support on non-Adafruit boards) and sensor libraries.
- Explain how to install libraries by copying the library files to the CIRCUITPY drive.
STEP 3: Example Projects
Simple Example Projects:
- LED Blink: Control an LED on the STM32F412 board to blink.
Code:
https://github.com/YakrooThai/STM32F412-Discovery/blob/main/Circuitpython/IntroLED.py
You can contact
E-mail: mhooyang@gmail.com
Please follow my YouTube channel. Still a newbie to make a YouTube channel.
Just press Subscribe my youtube channel. Thankyou
https://www.youtube.com/@Yakroo108 < ===== ( -/|\-)
Yakroo108
Jean-François Poilpret
