Hackaday.io Hackaday.io
Sign up Log in
Modular LED Triangle Wall Panel
I want to build a modular LED panel module using PCB-based LED matrices to display patterns and effects.
tanguyTanguy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.2k views
0 comments
7 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 9
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.2k
0
7
7
Team (1)
  • tanguyTanguy
Join this project's team
completed project
MISC
LED MATRIX led matrix pcb art lighting diy electronics Geometric triangle
This project was created on 11/09/2024 and last updated 2 years ago.
Starting from
Buy on Tindie
has orders / reviews
Ships from
Description
I want to build a modular LED panel module using PCB-based LED matrix to display patterns and effects.
Files
diffuser.STL
Standard Tesselated Geometry - 37.97 MB - 01/22/2025 at 13:36
Download
frame.STL
Standard Tesselated Geometry - 20.36 MB - 01/22/2025 at 13:36
Download
clip.STL
Standard Tesselated Geometry - 632.70 kB - 01/22/2025 at 13:35
Download
Project Logs
Collapse
  • Shiny! ✨
    Tanguy • 01/22/2025 at 13:30 • 0 comments
  • Module demo
    Tanguy • 12/18/2024 at 13:26 • 0 comments
  • Assembly in progress
    Tanguy • 12/16/2024 at 11:21 • 0 comments
  • Sponsoring PCBX
    Tanguy • 12/08/2024 at 12:25 • 0 comments
    A huge thank you to PCBX for sponsoring this project with their high-quality PCBs!
    If you're looking to order top-notch PCBs with fast production times, check out my referral link: https://link.pcbx.com/03bc. You'll receive FREE PCB and PCBA coupons for 10 standard PCBs!
  • Modules and Link Mechanism
    Tanguy • 11/20/2024 at 11:20 • 0 comments
  • PCB ready to go to production
    Tanguy • 11/16/2024 at 13:21 • 0 comments
  • 3D-printed casing and diffuser
    Tanguy • 11/13/2024 at 10:09 • 0 comments
  • CAO for triangle matrix case
    Tanguy • 11/10/2024 at 18:40 • 0 comments
  • Working on a PCB to hold all the leds
    Tanguy • 11/09/2024 at 13:08 • 0 comments
View all 9 project logs
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Modular LED Triangle Wall Panel", please tell us the reason.
Send message
Remove Member
