pi-setup.zipThis is all files needed to set up the mini dlna server.Just unzip this folder (and its files) into the pi home directory on the SD card and then edit the wpa_supplicant.conf file for your wifi and hotspot. Then run mini-pi-setup.sh by 'sudo ./mini-pi-setup.sh' to set up and copy all files. the script will reboot the media server afterwards Zip Archive - 7.70 kB - 11/13/2024 at 08:37 |
