#include <FirebaseESP32.h>
#include <SD.h>
#include <DHT.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <HTTPClient.h>
#include <SPI.h>
#include <Audio.h> // Include your audio library
#include <esp_task_wdt.h>
// Firebase setup
#define FIREBASE_HOST "your-project-id.firebaseio.com" // Your Firebase project
#define FIREBASE_AUTH "your-firebase-auth-key" // Your Firebase API key
// Pin Definitions
#define DHTPIN 13
#define DHTTYPE DHT11
#define GAS_PIN 34
#define SIM800_TX 17
#define SIM800_RX 16
#define SD_CS 5 // Chip select pin for SD card
#define AUDIO_PIN 23 // Pin connected to the audio output
DHT dht(DHTPIN, DHTTYPE);
SoftwareSerial sim800(SIM800_RX, SIM800_TX);
Audio audio; // Create an Audio object
// Firebase and SIM800 Setup
FirebaseData fbData;
String basePath = "/sensorData";
// Message and Sound Setup
String incomingSMS;
// SD Card setup for sound
File soundFile;
// Maximum number of retries for sending data to Firebase
const int MAX_RETRIES = 2;
// Watchdog timer configuration
const int WDT_TIMEOUT = 10; // Timeout set to 10 seconds
// Function prototypes
void sendCommandToSIM800(String command);
void checkSMSForCodes(String sms);
void playSound(String soundFileName);
void sendDataToFirebase(float temp, float hum, int gas, int AQI, String collectedTime, String sentTime);
String getISOTime();
int calculateAQI(int gasValue);
void playAlertAudio();
void playDisasterAudio(String code);
void rebootSystem();
void fullSystemScan();
void emergencyReboot();
void initSIM800();
bool isPlaying = false; // To track if audio is currently playing
void setup() {
Serial.begin(115200);
sim800.begin(9600);
esp_task_wdt_init(WDT_TIMEOUT, true);
esp_task_wdt_add(NULL);
// Initialize DHT sensor
dht.begin();
// Initialize SD card
if (!SD.begin(SD_CS)) {
Serial.println("SD card initialization failed");
return;
audio.setPin(AUDIO_PIN); // Set the pin for audio output
Serial.println("SD card initialized successfully");
// Firebase initialization
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
Firebase.reconnectWiFi(true);
// SIM800 initialization
initSIM800(); // Initialize the SIM module
void loop() {
static unsigned long lastSendTime = 0;
static int retryCount = 0;
esp_task_wdt_reset(); // Reset the watchdog timer
// Check for incoming SMS
if (sim800.available()) {
incomingSMS = sim800.readString();
checkSMSForCodes(incomingSMS);
// Read sensors
float temp = dht.readTemperature();
float hum = dht.readHumidity();
int gasValue = analogRead(GAS_PIN);
// Calculate Air Quality Index (dummy logic for now)
int AQI = calculateAQI(gasValue);
// Get timestamps
String dataCollected = getISOTime();
String dataSent = getISOTime(); // Assume data is sent right after collection
// Send data to Firebase with retries
bool dataSentSuccessfully = sendDataToFirebase(temp, hum, gasValue, AQI, dataCollected, dataSent);
if (!dataSentSuccessfully) {
retryCount++;
if (retryCount <= MAX_RETRIES) {
Serial.println("Retrying to send data...");
delay(5000); // Wait before retrying
sendDataToFirebase(temp, hum, gasValue, AQI, dataCollected, dataSent); // Retry sending data
} else {
Serial.println("Data send failed after retries. Performing full system scan and reboot.");
fullSystemScan(); // Perform full system scan
rebootSystem(); // Reboot the system
} else {
retryCount = 0; // Reset retry count on successful send
// Check if audio is playing
if (!isPlaying) {
playAlertAudio(); // Play the alert audio first
delay(10000); // Delay 10 seconds between readings
void initSIM800() {
sendCommandToSIM800("AT");
delay(1000);
sendCommandToSIM800("AT+CMGF=1"); // Set SMS text mode
delay(1000);
sendCommandToSIM800("AT+CNMI=1,2,0,0,0"); // Immediate SMS notification
delay(1000);
void sendCommandToSIM800(String command) {
sim800.println(command);
delay(1000);
while (sim800.available()) {
Serial.println(sim800.readString());
void checkSMSForCodes(String sms)...
