11Step 11
Hook RPI to power controller:
- PP1 - micro USB 5V
- PP6 - GND
Hook USB connector to charger power and ground, and to RPI usb data pads- PP22 - USB D+
- PP23 - USB D-
12Step 12
TODO:
- Finish cutting for new RPI placement, update pics
- Power controller
- Power/mode switch: Off / Lights (read-only?) / USB + development (read-write)
- USB connector / magnetic connector placement
- Inner C-Ring: cutout, EL-Wire or more LEDs
- Button
- I2C hardware + software: accel+gyro, RTC
- Software: light displays (Check out SPI DMA), read-only OS mode?
- Software: USB storage + display: % full, transfer rate (from sysstat/iostat)
- can USB eject be detected??? (other devices obviously can)
- WiFi client setup (seems to be working, I can see access points), wifi host
- Magnetic mount?
- Wireless Qi charging?: custom coil to fit space, may be able to boost working distance?
