GrowMore Hub Universal Controller
The GrowMore Hub Universal Controller is the first open-source networked 0-10v controller
Starting from
$43.99
fpovoski has 129 orders / 9reviews
Ships from United States of America
The GrowMore Hub Universal Controller is the first open-source networked 0-10v controller for the "Grower", agriculture, HVAC, and lighting applications. The GrowMore Hub is an ESP32-S3 based controller for temperature and humidity monitoring and control of 0-10v Electronically Commutated (EC) in-line fans, grow lights, and other related devices. This HUB features the powerful ESP32-S3 processor from Expressif, with integrated WiFi and Bluetooth functionality (BR/EDR/BLE).
Don’t be tied to one fan or lighting manufacturer’s devices or limited controller solutions, and especially not their non-networked or APP based controllers. The GrowMore Hub is versatile, flexible, and software customizable when required in an easy programming environment.
Product Description
Interfaces
The GrowMore Hub has four flexible individually controlled 0-10V ports, outputting either a 0-10v PWM digital signal or 0-10v analog signals, supporting a wide range of devices from numerous manufacturers that support this common standard. It has the ability to set the PWM or analog signal in 65536 steps unlike the 5 or 6 steps other controllers have. It also has the flexibility to output any maximum voltage level from 5v to 14v. It also monitors fan speed or other device outputs related to each of those device ports.
The GrowMore ports can also be used as DACs outputting 0.15 millivolt resolution at up to 20kHz.
It allows monitoring of temperature, humidity, and even pressure from multiple sensors, zone located, to allow you the flexibility for accurate control of temperature, humidity, and lighting condition for optimal plant growth.
Open Source, Open Protocols
Whether you are using the GrowMore Hub for a small grow tent, grow room, greenhouse, or many in an entire facility, the GrowMore Hub is the perfect solution for you. Moreover, since it implements open protocols for control and monitoring, whether you are using one or one hundred, you can control and monitor your installation through one interface.
Besides each Hub having its own webserver though WiFi, accessible from any browser, it supports the ubiquitous MQTT communications protocol and integrates into popular automation software like Home Assistant, Node-Red, ThingsBoard, and many others as well as popular voice assistant interfaces like Amazon Alexa and Google Home.
Versions
The GrowMore Hub comes in two versions, first the GrowMore Display Hub with a 2.4” LCD display and touchscreen, that allows device local monitoring and control through the touchscreen, and the second a headless GrowMore Standard Hub for remote control configurations. Moreover, you will be able to control and monitor any headless GrowMore Standard Hub, from one GrowMore Display Hub as well as the locally attached devices and sensors (currently in Beta).
Software
The GrowMore Hub allows manual setting of fan speeds or lighting intensity setting though its LCD display, or remotely via the network with the webserver interface, HTTP API, MQTT or HA API. You can also access temperature/humidity/pressure (depending on attached sensors) reading through the same interfaces, allowing easy integration into your own control system and algorithms.
Or in the alternative set one or all of the GrowMore Hub’s ports to “Auto Mode”, in which it will use its built-in PID algorithms to maintain a target temperature or humidity and automatically turn on, turn off, or set a devices levels based on a programmed schedule. Over-temperature or under-temperature alarms are also available as well as performance monitoring and detection of failed devices.
Cases
Both versions of the GrowMore Hub come in custom cases that can be attached to surfaces with two M3 screws or by its magnet base to ferrous metal surfaces.
Highly Customizable
The GrowMore Hub utilizes the ESPhome system software which provides an open-source environment and that allows sophisticated customers complete control over the operation...
  • 1
    Step 1
    Setup and Configuration
    • The Flash and Reset Buttons are recessed on the USB end of the GrowMore Hub. The inner button is the Reset Button and the Flash Button is to the outside. Use a large paper clip or similar diameter instrument to depress then if required.
    • Power is supplied by a connected EC inline fan, connected to ports P1-P4. It is HIGHLY SUGGESTED YOU ALWAYS POWER ALL YOUR FAN OFF WHEN CONNECTING DEVICES TO THE GROWMORE HUB. Although the HUB has protections in place, the is the wise thing to do otherwise damage to the HUB many occur.
    • To place on WiFi network use 2.4G phone to connect to "GrowMore Fallback Hotspot" with password "esphome1".. Once connected to your WiFi network, to access the webpage of the device browse to http://growmore.local
    • Device is flashed with an exmaple ESPhome binary image that has manual control over fans and automatic control which can be enabled based the target temperature setting. Four temperature sensors control each of the four PWM fan connectors. Flashed binary image has the Home Assistant "api:" enabled with MQTT with.
    • For customization, please make a request to esp32andmore@gmail.com for source code.
    • Also update WiFi and MQTT server credentials as required.
    • Flash over USB or ethernet. To flash over USB use ESPhome Web Flasher https://web.esphome.io/ with the device powered and connected to your host machine.
    • If you did not purchase the Dallas DS18B20 temeprature sensors from us, due to a recent change in ESPHome, the DS18B20 sensor address will need to be discover and a code compilation with the device being flashed.
View all instructions
