• In the Garden
    Neil Mundt • 05/16/2025 at 23:43 • 0 comments
  • Just In.. Drill
    Neil Mundt • 02/19/2025 at 22:32 • 0 comments
    Ordered some Green versions of my VinesLink module. Lucked out twice. Had to drill out more panels. Because the 3.5mm PCB Holes didn't fit again. I must of sent the wrong panel revision. But I got the Drill to burr. Really like how the Green Panels Turned out. They really Vibe with the Jungle Theme. Really Like the added Feature of the inside case Jack as a option for routing.
  • First prototype module housed In my DIY SYNTHESIZER
    Neil Mundt • 02/14/2025 at 08:00 • 0 comments
    Well here we are finally finished a Eurorack Module. Glad the way it turned out. All the pieces came together and now I have a great module that does quite a bit as a utility module.
  • OO Wee Here goes the Final Revision
    Neil Mundt • 02/01/2025 at 20:19 • 0 comments
    I really liked the Idea that I got and was able to squeeze a alternative jack on the back of the module. So you can have more room for more of those pesky cables in front and back. Going to have many a grooves played through this adaptor. More Blinky lights the better.
  • ADDed a Backsided Jack as a option for my system
    Neil Mundt • 01/31/2025 at 07:13 • 0 comments
    Added a Back jack to a prototype that allows you to wire the patches on the inside of the synth with an cable. I might add another option for a backsided patches. Really liking the features of it.
  • Got my Protype Boards. Looking forward to testing
    Neil Mundt • 01/29/2025 at 11:08 • 0 comments
  • Finished A Blender GIF of the Final PCBS.
    Neil Mundt • 01/16/2025 at 03:58 • 0 comments
    Just Finished the Last version Blender Animation. I think it turned out really well and it is showing some improvements in my use of blender for these projects.
  • Finalised Design
    Neil Mundt • 12/31/2024 at 00:05 • 0 comments
    This is pretty much the finalised design. I think it turned out great. I think as a Passive module is pretty feature complete compared to the Original Design. Really like how the artwork turned out. Not bad for my First use of SMT Parts.
    0
    0
  • The More Blinky Lights for the Better
    Neil Mundt • 12/24/2024 at 00:40 • 0 comments
          Added The Feature to Display incoming Signals to the Jacks. When the Jacks are Unplugged  You can Visually see Incoming Signals. When you Plug a jack in the LEDs are Disconnected to prevent any Voltage Drop to the Patch. The module is still passive and I think it is Quite a clever way to add some Visual Feedback to this module.  Still got a few Refinements to do. Before I order the First Prototype.
  • Adding LED Channel Signal Indications
    Neil Mundt • 12/21/2024 at 04:10 • 0 comments
    I am adding a optional LED SMD indication for signals. Which is a SMD LED behind the jack on the backside of the PCB.  I got the idea from benjiaomodular Mini DIV. Benjiaomodular Project The LEDs will tell the user what channels are being used when unplugged. I think it is a very good idea. The module will still be passive getting lit by the sent voltages over Rj45 connector. When Plugged into the jack it will disconnect the LED So there wont be any voltage drop with the LED.
