Ordered some Green versions of my VinesLink module. Lucked out twice. Had to drill out more panels. Because the 3.5mm PCB Holes didn't fit again. I must of sent the wrong panel revision. But I got the Drill to burr. Really like how the Green Panels Turned out. They really Vibe with the Jungle Theme. Really Like the added Feature of the inside case Jack as a option for routing.
Well here we are finally finished a Eurorack Module. Glad the way it turned out. All the pieces came together and now I have a great module that does quite a bit as a utility module.
I really liked the Idea that I got and was able to squeeze a alternative jack on the back of the module. So you can have more room for more of those pesky cables in front and back. Going to have many a grooves played through this adaptor. More Blinky lights the better.
Added a Back jack to a prototype that allows you to wire the patches on the inside of the synth with an cable. I might add another option for a backsided patches. Really liking the features of it.
Just Finished the Last version Blender Animation. I think it turned out really well and it is showing some improvements in my use of blender for these projects.
This is pretty much the finalised design. I think it turned out great. I think as a Passive module is pretty feature complete compared to the Original Design. Really like how the artwork turned out. Not bad for my First use of SMT Parts.
Added The Feature to Display incoming Signals to the Jacks. When the Jacks are Unplugged You can Visually see Incoming Signals. When you Plug a jack in the LEDs are Disconnected to prevent any Voltage Drop to the Patch. The module is still passive and I think it is Quite a clever way to add some Visual Feedback to this module. Still got a few Refinements to do. Before I order the First Prototype.
I am adding a optional LED SMD indication for signals. Which is a SMD LED behind the jack on the backside of the PCB. I got the idea from benjiaomodular Mini DIV. Benjiaomodular Project The LEDs will tell the user what channels are being used when unplugged. I think it is a very good idea. The module will still be passive getting lit by the sent voltages over Rj45 connector. When Plugged into the jack it will disconnect the LED So there wont be any voltage drop with the LED.
