[B][P] 6-core cable and joystick PCBs
A project log for Tetizmol [gd0153]
A Tetwice-layout keyboard designed to be abysmal.
kelvinakelvinA 02/06/2025 at 15:290 Comments
The PS5 joystick PCBs ontop of the 6-core telephone cable
Most things from the BOM (see below) are going to be delayed due to Lunar New Year celebrations, but 2 components have arrived.
I was unable to figure out a good way to mount the joysticks without needing the PCB's, so that's why I got them.
The reason why I got the telephone cable and not some other type of multicore cable is because it was low-cost and each internal wire is single core, which has the following benefits:
As seen below, I was able to use snippers to score the insulation and then use needlenose pliers to pull it off:
I then measured its dimensions:
It also seems possible to remove the outer insulation with snippers, but I believe a dedicated 50p tool is still worth the investment considering I'd need to do this at least 22 times:
