ARDUINOOOOOOOOOO
Spent most of session messing with the IDE and sensors. Not much prior experience leads to alot of testingand time wasting but the vibrating motor worked out along with the force sensor.
We saved the code for later use.
Got to know force sensor surface area kinda small so might be pain to use.
Same vibration motor too small to actual feel so eyes and ears might be the play.
Lights and buzzers is what we will use.
