This week we went for the laser cutting and printed out the stencils on a semi wodden sheet. We had few chocies for material but it made the most sense. Took help from the professor in cutting of the parts.
Issue with LEDs arrised had to add more breadboards to add parallel connects.
Issue with grounding were also there but fixed them eventually after alot of brainrot.
Glued the base structure expect the top to add the wirings in the later session.
Final assembly with some tweeks left.
Harmanpreet Singh
