First Entry
A project log for Blue Dmod v1.1
Proper PCB design and less components for updated Blue Dmod.
uhpowerupuhpowerup 11/19/2024 at 15:030 Comments
Designed the PCB and reduced few component's like CW 025 relay module,  driving 5VDC relay directly from Pro Micro using BC547 Transistor.  Added a 10K pot to select the Delay of Relay switching (prototype was only possible via code). Using new BT003 Bluetooth module as SMD.
