PCB revision and customization options
A project log for Blue Dmod v1.1
Proper PCB design and less components for updated Blue Dmod.
uhpowerupuhpowerup 11/21/2024 at 06:570 Comments
With careful consideration and few feed backs, I have decided not to hard mount the I/O port on PCB. It will be 5 pin unpopulated header you can choose to connect appropriate connector or hard wire it to your Radio. My best suited option for ports is M12 data connector, GX12 aviation connector or RJ45 port.
In addition, I have left the power system alone will be totally users’ discretion. You can use “MH-CD-42” Charging and 5VDC booster module.
User can use “J1” jumper setting to select PTT_M to contact Ground when PTT is triggered or have PTT_S if the radio PTT is triggered using internal pins.
Previously uploaded Pictures will be replaced by new ones.
Will keep everyone updated on further developments.
73’s
2E0UMR
