PCB had a issue, new PCB have a cut out for Bluetooth antenna to reduce interference.
You can choose any of the code if you would like to potentiometer then use "BlueDmod-1.1_rev1.2_POT".
if you do not want to use potentiometer then use "BlueDmod-1.1_rev1.2_non_POT" a default delay of 1000ms is implemented.
