New PCB just arrived, will upload files after tests. also modified old PCB and tested all worked as expected. Still trying to find a Power boost circuit without low current shut off. Found easy way to use cheap power bank to power the circuit.
Moded PCB removed a pad on the left side of Bluteooth module. also Relay pads were small size.
Assembled PCB and testing.
Will keep you posted.
73's
2E0UMR.
uhpowerup
