New PCB just arrived, will upload files after tests. also modified old PCB and tested all worked as expected. Still trying to find a Power boost circuit without low current shut off. Found easy way to use cheap power bank to power the circuit.
![](https://cdn.hackaday.io/images/6217321733508254324.jpg)
Moded PCB removed a pad on the left side of Bluteooth module. also Relay pads were small size.
![](https://cdn.hackaday.io/images/8162291733508354420.jpg)
Assembled PCB and testing.
![](https://cdn.hackaday.io/images/5737801733508415917.jpg)
![](https://cdn.hackaday.io/images/9533621733508416085.jpg)
![](https://cdn.hackaday.io/images/8800681733508417911.jpg)
Will keep you posted.
73's
2E0UMR.
